USB4 Gen2x2 Type-C Bi-Directional USB-IF Certified Cable 4K60Hz, Data 20Gbps, PD 240W(48V/5A) EPR M/M 2m/6.56ft
The Club 3D CAC-1575 USB4 Gen2x2 Type-C Bi-Directional USB-IF Certified Cable, Video up to 4K60Hz, Data 20Gbps, PD 240W(48V/5A) EPR, Extended Power Range M/M 2m/6.56ft connects your Notebook, Tablet or Phone with USB4 Type-C output to your favorite existing Peripherals, Accessories and Chargers. It enables Video,Data and Power over a single cable and both ways. This cable supports USB4 Gen2x2 data up to 20Gbps, Video up to 4K60Hz and up to 240Watt(48V/5A) EPR (Extended Power Range) output for Downstream charging or powering your Notebook, Tablet or Smartphone and is USB-IF Certified.
Product Name: |
USB4 Gen2x2 Type-C Bi-Directional USB-IF Certified Cable 4K60Hz, Data 20Gbps, PD 240W(48V/5A) EPR M/M 2m/6.56ft |
Product Series: Cables |
Product Code: CAC-1575 |
EAN code: 8719214472313 |
UPC code: 841615102563 |
• Video max. 4K60Hz |
• USB4 Gen2x2 Data 20Gbps |
• 240W EPR(Extended Power Range)Charging through a single cable |
• Fully Bidirectional |
• E-marker IC |
• Data speed up to 20Gbps |
• USB Power Delivery, 240 Watt(48V/5A) charging |
• Input Reversible USB Type-C connector Male |
• USB-IF Certified |
• Works with Windows, Apple OS X, Chrome OS |
• USB4 Gen2x2 Type-C Bi-Directional USB-IF Certified Cable 4K60Hz, Data 20Gbps, PD 240W(48V/5A) EPR M/M 2m/6.56ft |
Available Interfaces |
• USB Type-C Male |
• USB Type-C Male |
• Box size: 14.5 x 14.5 x 4.5cm 5.71 x 5.71 x 1.77" |
• Total Cable length approx.: 2 m / 6.56 ft |
• USB Type-C Male Connector dimensions: 3.62 x 1.2 x 0.63 cm / 1.43 x 0.47 x 0.25" |
• Cable Weight: 105 gr / 3.71 oz |
• Box Weight: 45 gr / 1.59 oz |
• Total Weight: 150 gr / 5.29 oz |
- CAC-1575_SPECIFICATION-SHEET_EN.pdf
- CAC-1575_SPECIFICATION-SHEET_DE.pdf
- CAC-1575_SPECIFICATION-SHEET_ES.pdf
