HDMI + Micro USB to DisplayPort 4K120Hz or 8K30Hz M/F Active Adapter
The Club 3D CAC-1335 is the perfect solution to connect to any DisplayPort™ 8K30Hz or 4K120Hz ready displays from a HDMI™ source which does supports these resolutions/specifications.
If you have a PC or any other device that lacks the new DisplayPort™ 8K30Hz or 4K120Hz specifications, the Club3D CAC-1335 will be the simple way to connect your HDMI™ source device to your new 4K120Hz or 8K30Hz display(provided your source supports these resolutions).
The Adapter is powered thru a Micro USB port(5V/1.5A). An USB Type-A to Micro USB M/M 1m / 3.28 ft is supplied in the box.
CAC-1335 QUICK INSTALLATION GUIDE
HDMI to DisplayPort 4K60Hz M/F Active Adapter
HDMI to DisplayPort Adapter
DisplayPort™ 1.4 HBR3 Cable VESA Certified  M/M 2 m / 6.56ft 28AWG
HDMI™+ Micro USB to DisplayPort™ 4K120Hz or 8K30Hz M/F Active Adapter
Product Series: Adapter
Product Code: CAC-1335
EAN code: 8719214472498
UPC code: 841615102747
• Compliant with VESA DisplayPort™ Specifications up to 3840x2160/120Hz or 7680x4320/30Hz
• Compliant with HDMI™ Specifications up to 3840x2160/120Hz or 7680x4320/30Hz
• Support Max. resolution/refresh rates up to 4K120Hz or 8K30Hz
• Adapter is separatly powered thru a Micro USB Female port 7.5Watt (5V/1.5A)
• USB Type-A to Micro USB M/M 1m / 3.28 ft cable is supplied in the box
Applications:
• For devices like laptop, desktop, gaming and display systems like TV.
• Perfect for Host Devices which are featured with video signal output for gaming, commercial applications.
Supported resolutions:
• Support Max. resolution/timing up to 4K120Hz or 8K30Hz
• ONLY games which are designed for 4K120Hz will provide this experience
This adapter will function with lower specifications GPU’s, be aware performance will be reduced due to the specifications of that GPU !!
• Microsoft, Mac OS
• CAC-1335 HDMI™+ Micro USB to DisplayPort™ 4K120Hz or 8K30Hz M/F Active Adapter
• USB Type-A to Micro USB M/M 1m / 3.28 ft cable for powering the adapter
• 1x HDMI™ (Male)
• 1x Micro USB (Female)
• 1x DisplayPort™ (Female)
• Box size 14.5 x 14.5 x 4.5 cm / 5.71 x 5.71 x 1.77"
• Device size: 7.2 x 3 x 1.2 cm / 2.83 x 1.18 x 0.47"
• Device Weight: 28 gr / 0.99 oz
• Total Cable length: Approx. 26 cm / 10.24"
• Power Cable length: 1m / 3.28 Ft
• Power Cable Weight: 21 gr / 0.74 oz
• LDPE Bag Weight: 5gr / 0.18 oz
• Connector dimensions :
- HDMI™ Male: 4 x 0.7 x 1.8 cm / "
- USB Type-A Male: 3.7 x 0.7 x 1.5 cm / 1.46 x 0.28 x 0.6"
- Micro USB Male: 2.8 x 0.6 x 1 cm / 1.1 x 0.24 x 0.39"
• Box Weight: 45 gr / 1.59 oz
• Total Weight: 99 gr / 3.5 oz
Note:
