MiniDisplayPort 1.4 to HDMI 4K120Hz or 8K60Hz HDR10+ Cable M/M 1.8m / 6ft
MiniDisplayPort™ 1.4 ready PC or any other device that lacks the new HDMI™ 4K120Hz or 8K60Hz specification, the Club 3D CAC-1187 will be the simple way to upgrade your device and connect to your new TV*.
With its DP1.4 DSC video compression technology, this adapter is able to convert DP1.4 video signals to HDMI™, supporting video display resolutions up to 8K (7680x4320/60HZ or 3840x2160/120Hz)** and creating life like colors and movements with HDR10+ giving users the ultimate visual experience. The Adapter is powered thru the MiniDP™ port.
Product Name: |
MiniDisplayPort™ 1.4 to HDMI™ 4K120Hz or 8K60Hz HDR10+ Cable M/M 1.8m / 6ft |
Product Series: Cable |
Product Code: CAC-1187 |
EAN code: 8719214472535 |
UPC code: 841615102778 |
• Compliant with VESA DisplayPort™ v1.4 Specification |
• Support 8/10/12 bit color depth |
• Support pixel format RGB/YCbCr4:4:4/YCbCr4:2:2/YCbCr4:2:0 |
• Compliant with HDMI™ 2.1 Specification |
• Support both HDCP 1.4 and HDCP 2.3 |
• Support DSC v1.2a and backward compatible with the former version |
• Support Max. resolution/refresh rates up to 4K120Hz or 8K60Hz |
• Support Dynamic HDR10+ |
• Support 1 to 32 channels LPCM 192kHz audio output |
• Supports HBR audio up to 1536kHz |
Applications: |
• For the host device like laptop, desktop, video converter adaptor, docking station, projector, gaming and display system like TV*, digital signage, VR/AR system. |
• Perfect for Host Devices which are featured with the DP1.4 graphic card that supports MiniDP video signal output for gaming, commercial applications**. |
Supported resolutions: |
• Support Max. resolution/timing up to 4K120Hz or 8K60Hz |
This adapter will function with lower specifications GPU’s, be aware performance will be reduced due to the specifications of that GPU !! |
• Microsoft, Mac OS |
• CAC-1187 MiniDisplayPort™ 1.4 to HDMI™ 4K120Hz or 8K60Hz HDR10+ Cable M/M 1.8m / 6ft |
Available Interfaces |
• 1x MiniDP (Male) |
• 1x HDMI™ (Male) |
• Box size: 14.5 x 14.5 x 4.5cm / 5.71 x 5.71 x 1.77" |
• Cable Length : 1.8m / 6ft |
• Connector dimensions: |
- MiniDisplayPort™ Male 3.42 x 1.06 x 0.8 cm / 1.35 x 0.42 x 0.31" |
- HDMI™ Male 6.3 x 2 x 1.1 cm / 2.48 x 0.79 x 0.43" |
• Cable Weight: 63 gr / 2.22 oz |
• Box Weight: 45 gr / 1.59 oz |
• LDPE Bag Weight: 5gr / 0.18 oz |
• Total Weight: 113 gr / 3.99 oz |
Note: - Please update your TV Firmware to the version which supports these resolutions/refresh rates ! - Please update your Graphic drivers on your PC and make sure that DSC1.2 is supported on your devices to support the these resolutions/refresh rates! |
- CAC-1187_SPECIFICATION-SHEET_EN.pdf
- CAC-1187_SPECIFICATION-SHEET_DE.pdf
- CAC-1187_SPECIFICATION-SHEET_ES.pdf
