DisplayPort 2.1 Bi-Directional VESA DP80 Certified Cable 4K240Hz, 8K60Hz or 10K30Hz M/M 1.2m/3.94ft
The Club 3D CAC-1091 DisplayPort™ 2.1 Cable enables the connection of your DisplayPort™ supported (Gaming) PC or Laptop to an (Ultra) High Resolution Monitor or other DisplayPort™ supported device. DisplayPort™ 2.1 UHBR10/13.5/20 up till 80 Gbps, also has support for Display Stream Compression 1.2 (DSC), Forward Error Correction, and extends the maximum number of inline audio channels to 32. It features locking DisplayPort™ connectors providing a secure, dependable connection, with NEW contact fingers special designed for these high speeds. Simply press the built-in one-touch latch button to unlock the connector. The soft UltraFlex jacket protects the cable from bends and deformation damage.
DisplayPort™ 1.4 HBR3 Cable VESA Certified  M/M 2 m / 6.56ft 28AWG
Product Name: DisplayPort™ 2.1 Bi-Directional VESA DP80 Certified Cable 4K240Hz, 8K60Hz or 10K30Hz M/M 1.2m/3.94ft
Product Series: Cables
Product Code: CAC-1091
EAN code: 8719214472696
UPC code: 841615102938
• Fully DisplayPort™ Version 2.1 Compliant, UHBR10/13.5/20 up till 80 Gbps
• DP80 Compliant
• New DP2.1 spec connector
• Support resolutions up to 4K240Hz or 8K60Hz
• Fully Bidirectional
• VESA Certified
• 1x CAC-1091 a DisplayPort™ 2.1 Bi-Directional VESA DP80 Certified Cable 4K240Hz, 8K60Hz or 10K30Hz M/M 1.2m/3.94ft
• DisplayPort 2.1 Male (NEW DP80 connector)
• Box size: 14.5 x 14.5 x 4.5cm 5.71 x 5.71 x 1.77"
• Total Cable length approx.: 1.2m / 3.94ft
• DisplayPort™ Male Connector dimensions: 3.62 x 1.2 x 0.63 cm / 1.43 x 0.47 x 0.25"
• Cable Weight: 85 gr / 3 oz
• Bio Degradable Bag Weight: 5 gr / 0.17 oz
• Box Weight: 45 gr / 1.59 oz
• Total Weight: 135 gr / 4.76 oz
