DisplayPort™ 2.1 DP54™ VESA® Certified Cable 8K120Hz 3m/ 9.84ft
• HIGH PERFORMANCE: DP™ 2.1 Cable is designed for UHBR13.5-enabled DisplayPort™ devices; DP54™ supports 54Gbps for 8K120Hz video and higher refresh rates at lower resolutions; Flexible TPE jacket routes well in tight spaces and withstands up to 120-degree bends
• FULL DP™ COMPATIBILITY: The VESA® Certified DP™ 2.1 Cable enables seamless compatibility with DisplayPort™ devices; Full-featured DP™ 2.1 performance and backward compatibility with DP™ 2.0/1.4/1.2 are guaranteed
• QUALITY CONSTRUCTION: Nickel-plated ends rated beyond 10,000 insertions; Latching DP™ connectors w/strain reliefs prevent accidental disconnection; Braided aluminum shield for enhanced EMI protection; TPE jacket is durable, halogen-free, and RoHS compliant
• VERSATILE PERFORMANCE: DisplayPort™ 2.1 DP54™ supports 54Gbps across four UHBR13.5 (13.5Gbps) lanes to enable consistent high throughput; Ideal for 8K displays, high performance GPUs, MST multi-monitor daisy chains, and docking stations; Supports 32-ch audio
• SPECS: Black; 9.84 ft (3 meter); DisplayPort™ 2.1 supports UHBR10-13.5/ HDR/MST/DSC 1.2/HDCP 2.2; DP54™ (54Gbps); 8K120Hz/DSC; 32-ch Audio; Compatible w/DP™ 2.0/1.4/1.2; Latching DP™ Connectors; 26AWG; 6.5mm (0.26in) O.D.
Product Name: DisplayPort™ 2.1 DP54™ VESA® Certified Cable 8K120Hz 3m/9.84ft |
Product Series: Cable |
Product Code: CAC-1093 |
EAN code: 8719214473259 |
UPC code: 841615103508 |
• Fully DisplayPort™ Version 2.1 Compliant, UHBR10/13.5 up till 54 Gbps |
• DP54™ Compliant, VESA® Certified |
• Downwards compatible to older DisplayPort™ standards |
• Support resolutions up to 8K120Hz or 4K240Hz |
• Fully Bidirectional |
• Windows 10 or upwards, macOS 15.0 |
• 1X CAC-1093 DisplayPort™ 2.1 DP54™ VESA® Certified Cable 8K120Hz 3m/ 9.84ft |
Available Interfaces: |
Input: DisplayPort™ 2.1 Male |
Output: DisplayPort™ 2.1 Male |
• Box Size approx.: 17.5 x 17.5 x 4.5 cm / 6.89 x 6.89 x 1.77in |
• Cable length approx.: 3m/ 9.84ft |
• Connector dimensions approx.: 3.62 x 1.2 x 0.63 cm / 1.43 x 0.47 x 0.25in |
• Product Weight: 198gr / 6.98oz |
• Box Weight: 63gr / 2.22 oz |
• Bio Degradable Bag size approx.: 28 x 25 cm / 11 x 9.84in |
• Bio Degradable Bag Weight: 4 gr / 0.14 oz |
• Total Weight: 265gr / 9.35oz |
- CAC-1093-SPECIFICATION-SHEET_EN.pdf
- CAC-1093-SPECIFICATION-SHEET_DE.pdf
- CAC-1093-SPECIFICATION-SHEET_ES.pdf
