USB 3.2 Gen1 Active Repeater Cable 15m/ 49.2 ft M/F 28AWG
With this Club3D USB 3.2 Gen1 Active Repeater Cable CAC-1403, you can go far beyond the standard USB Cable length limitation of 3 meters, without loss of Data Transfer Speed. The USB 3.2 Gen1 Active Repeater Cables are fully Plug & Play and do not require any driver installation. Just connect your external USB device like External HDD/NAS/Digital Camera or External USB Graphics to your system with the CAC-1403 and have flexibility of the increased 15 meters of extra cable length. Also for a VR experience at the sofa away from the notebook or PC this cable provides you with the freedom of movement.
The CAC-1403 supports data transfer rates up to 5Gbps over the full length of the cable.
Please use one of our Club 3D (Extension) cables to connect from the Adapter Cable to your devices:
In case you need assistance to choose the correct cable, please visit our website www.club-3d.com or feel free to mail us at [email protected] and it will be our pleasure to assist you.
Product Name: USB 3.2 Gen1 Active Repeater Cable 15m/ 49.2 ft M/F 28AWG |
Product Series: Cables |
Item code: CAC-1403 |
UPC code: 854365005336 |
EAN code: 8717249401254 |
• USB 3.2 Gen1 SuperSpeed specification |
• Supports data transfer speeds up to 5 Gbps |
• Plug and play functionality |
• No drivers required |
• Cable: 28AWG, OD: 7mm |
• Windows™ and Mac OSX™ compatible |
OS Support: All |
• 1x CAC-1403 Active Repeater Cable 15 m/ 49.2 ft Male/Female |
• 1x Power Supply Input 100-240V 50/60Hz 0.35A max-Output 5V 2000mA |
Available Interfaces: |
• 1x USB 3.2 Gen1 Male |
• USB 3.2 Gen1 Female |
• Box size 21 x 21 x 7.5 cm / 8.27 x 8.27 x 2.96 inch |
• Cable Weight: 1077 gr / 38 oz |
• Total Cable length 15m / 49.2 ft |
• Connector dimensions: |
- USB Type A Male 4 x 0.7 x 1.5 cm / 1.57 x 0.28 x 0.6 inch |
- USB Type A Female 7.5 x 1.3 x 2.2 cm / 2.96 x 0.51 x 0.87 inch |
• Box Weight 112 gr / 3.95 oz |
• Total Weight: 1189 gr / 41.94 oz |
- SPECIFICATION SHEET_CAC-1403_EN.pdf
- SPECIFICATION SHEET_CAC-1403_DE.pdf
- SPECIFICATION SHEET_CAC-1403_ES.pdf
