USB Type A and C Power Charger, 5 ports up to 111W
CAC-1903 - The Club3D CAC-1903 USB Type A and C, Power Charger, 5 ports up to 111W, with 4x USB Type A and 1x USB Type C connectors is designed for users who want to use only 1 Power Charger for their PC/Laptop/Tablet/Mobile phone as well as their docking station. It has a separate power cord for use into a wall socket.
By adopting PowerDelivery charging technology, this versatile Power Charger provides you with both charging function through 4 times USB Type A and 1x USB Type C interface, you can charge any connected Mobile phone / Tablet / NoteBook or any other supported devices. Furthermore we bundle the USB Type C cable for your convenience.
Charging
By adopting PD Charging technology and charging function through both USB Type A and Type C interfaces the Club3D Power Charger offers versatile and unique functionality with its 5 ports. It will charge your devices up to 111 Watts. Built-in safeguards protect your devices against excessive current, overcharging and overheating.
USB Type A and C Dual Power Charger up to 60W
USB TYPE C POWER CHARGER UP TO 27W
Product Name: USB Type A and C Power Charger 5 ports up to 111W
Product Series: Power Charger
Itemcode: CAC-1903
EAN code: 8719214471354
UPC code: 841615101542
USB-IF TID: 7298 / 7301
• Multi purpose 5 Port USB Power Charger
• Supports PD charging
• Provide power up to 111W input:100-110/240VAC
• Bundled with a USB Type C Power cable
• 4 ports USB Type A and 1 port USB Type C
• 1x USB Type C port supports PD charging with max 87W(20V/4.35A)
• 4x USB Type A ports supports PD charging with max 24W(5V/4.8A)
• Bundled with a powercord (country specific version)
• Eliminates the need for multiple Power Chargers
• Light weight and easy installation
• CAC-1903 USB Type A and C Power Charger 5 ports
• Powercord depending on Country (Specify on order)
• 1x RED USB Type C cable (1m/39,3Inch) for connecting to Host
• AC power plug
• 1x USB Type C Male
• 5xUSB Type A Male
• Box size: 17,5 x 15,5 x 5,5 cm
• Box size: 6,8 x 6,1 x 2.22 inch
• Device size: 10,2 x 2.54 x 6 cm
• Device size: 4 x 1.2 x 2.36 inch
• Device Weight: depending on power plug ≈ 425 gr. / 15 oz.
• USB C cable Weight: 35 gr. / 1,2 oz.
• Box Weight: 85gr. / 3 oz.
• Total Weight: depending on power plug ≈ 666 gr./ 23,5 oz.
Warning Safe Usage: Only to be used at altitude 2000 meters/6562 feet and below.
  • No HR images found
