Mini DisplayPort 1.4 to DisplayPort Extension Cable 8K60Hz DSC 1.2 HBR3 HDR Bidirectional F/M 1m/3.28ft
CAC-1120 - Club 3D Mini DisplayPort™ to DisplayPort™ 1.4 Extension Cable 8K60Hz DSC1.2 HBR3 HDR enables the connection of your Mini DisplayPort™ supported (Gaming) PC or Laptop to any standard Displayport cable to extend the distance to your DisplayPort™ supported Television, Monitor, Projector or other DisplayPort™ supported device. DisplayPort™ 1.4 adds support for Display Stream Compression 1.2 (DSC), Forward Error Correction, and extends the maximum number of inline audio channels to 32.
It features locking DisplayPort™ connectors providing a secure, dependable connection. Simply press the built-in one-touch latch button to unlock the connector.
The soft UltraFlex jacket protects the cable from bends and deformation damage. The Cable is 32AWG and fully Bi-Directional.
Product Name: Mini DisplayPort™ to DisplayPort™ 1.4 Extension Cable 8K60Hz DSC1.2 HBR3 HDR F/M 1m/3.28ft |
Product Series: Cable |
Itemcode: CAC-1120 |
EAN code: 8719214471446 |
UPC code: 841615101627 |
• Fully DisplayPort™ Version 1.4 Compliant, HBR3, HDR 32.4Gbps |
• Support for Forward Error Correction (FEC) |
• Downwards compatible to older DisplayPort standards |
• Support resolutions up to 8K @ 60Hz and 4K @ 144Hz |
• The Cable is 32AWG and fully Bi-Directional |
• All |
• CAC-1120 Mini DisplayPort™ to DisplayPort™ 1.4 Extension Cable 8K60Hz DSC1.2 HBR3 HDR F/M 1m/3.28ft |
• Mini DisplayPort™ 1.4 Female |
• DisplayPort™ 1.4 Male |
• Carton Box size: 14.5 x 14.5 x 4.5 cm. |
• Carton Box size: 5.7 x 5.7 x 1.77 inch |
• Retail Box Weight: 50 gr. / 1.76 oz. |
• Cable Weight: 42 gr. / 1.48 oz. |
• LDPE Bag: 5 gr. / 0.17 oz. |
• Total Weight: 97 gr. / 3.42 oz. |
• Cable 100 x 2 x 1 cm |
• Cable 39.37 x 0.78 x 0.39 inch |
• Made in China |
