USB Type C 3.2 Gen1 7in1 Hub HDMI 4K60Hz SD TF Card slot 2x USB Type A USB Type C PD RJ45
CSV-1592 - The Club 3D Hub is a USB Type C 7-in-1 Hub to HDMI™ 4K60Hz /SD-TF Card slot / 2x USB Type A / USB Type C PD / RJ45, providing an ideal solution for extending the port of USB Type C or Thunderbolt™ 3 host (PC/Laptop/tablet/Mobile phone, etc.),especially for the host with a single USB Type C port. This hub adopts the latest DP 1.4 Alt mode technology available today, enabling to output HDMI™ video with max 4k/60Hz and at the meanwhile transfer USB 3.1 data with max 5Gbps. 2x USB Type A ports allow you to connect 2 USB devices simultaneously.
SD/Micro SD allow to insert 2 card slots simultaneously for data transmission or for reading/writing information on the host. RJ45 ports allows the host to get access to Gigabit Ethernet. Besides, the USB Type C female supports PD 3.0 with max 100W PD Charging. It can work on all USB Type C and Thunderbolt™3 host that supports DP Alt mode(including DP1.2 and DP1.4 Alt mode).When working on Thunderbolt™3 host, this product transmits DP signal.
Product Name: USB Type C 7-in-1 Hub to HDMI™ 4K60Hz /SD-TF Card slot 2x USB Type A / USB Type C PD / RJ45 |
Product Series: Docking Station |
Itemcode: CSV-1592 |
EAN code: 8719214471477 |
UPC code: 841615101658 |
• Upstream: |
USB Type C Male (Connection to host) |
Support DP 1.4 Alt mode, with bandwidth max 2 lanes 16.2Gbps |
(8.1Gbps per lane),downward compatible with DP1.2 Alt mode |
Note: To get max bandwidth, the host should support DP 1.4 Alt mode with DSC format. |
• Downstream: |
Support HDMI™ max 4K/60Hz 4:4:4, 8bit with 18Gbps Bandwidth |
Support 6/8/10/12 bit color depth output |
Support output pixel format RGB 4:4:4/YCbCr 4:4:4/YCbCr 4:2:2 |
Support HDCP 2.2&HDCP1.4 |
Support HDR |
Note: When connecting a DP 1.4 Alt mode supported host, the max resolution of HDMI is 4k/60Hz; When connecting a DP 1.2 Alt mode supported host, the max resolution of HDMI™ is 4k/30Hz due to bandwidth limitation |
• 2x USB Type A 3.0 |
1- USB Type A port supports BC 1.2 with max. 7.5W([email protected]) downstream charging, |
2- USB Type A share max. 8W (5V/1.6A) downstream charging. |
Max 5Gbps bandwidth per USB Type A port |
• SD/Micro SD |
Support Secure Digital v3.0 UHS-I (Ultra High Speed)SDR12 (12.5Mbyte/s)/SDR25(25Mbyte/s)/SDR50(50Mbyte/s)/DDR50(50Mbyte/s)/SDR104(104Mbyte/s) |
• RJ45 (Gigabit Ethernet) Support 10Mbps/100Mbps/1000Mbps |
• USB Type C Female (for PD Charging) |
Support PD Charging 100W (20V/5A) |
Support Fast Role Swap of PD 3.0, the connected device will not get disconnected while plugging in and out PD Adapter |
8W is dedicated to the functioning of this product, the rest power (max 92W) will be passed to charge for the host |
OS Support: All |
• CSV-1592 USB Type C 7-in-1 Hub to HDMI™ 4K60Hz /SD-TF Card slot / 2xUSB Type A / USB Type C PD / RJ45 |
• User Manual |
Available Interfaces: |
•Upstream : |
- 1x USB Type C Male (Host connection) |
•Downstream : |
- 1x HDMI™ Female for connecting to Monitor |
- 1x SD Card Slot |
- 1x Micro SD Card Slot |
- 2x USB type A, BC1.2 charging |
- 1x USB Type-C female PD (Charging + Data) |
- 1x RJ45 |
• Box size 32 x 6 x 3 cm |
• Box size: 12.6 x 2.36 x 1.18 inch |
• Device size: 13.6 x 3.4 x 1.4 cm |
• Device size: 5.36 x 1.34 x 0.55 inch |
• Device Weight: 69 gr / 2.4 oz |
• LDPE Bag Weight: 5gr/ 0.2 oz |
• Box Weight: 36 gr / 1.3 oz |
• Total Weight: 110 gr / 3.9 oz |
- No HR images found
