USB 3.2 Gen1 Type-C to Micro USB Cable M/M 1m /3.28ft
The Club 3D CAC-1526 USB 3.2 Gen1 Type-C to Micro USB Cable enables the connection of your existing USB Type C output connections, Laptops, tablets and Ultrabooks, Power Chargers, etc. to Micro USB inputs, like camera's, Phones and our range of extension cables and adapters.
The cable is backwards compatible and supports USB 3.0 and USB 2.0 as well. The USB 3.2 Gen1 specification ensures a bitrate of 5Gbps for transfer of large files.
USB 3.2 Gen1 Type-A to Micro USB Cable M/M 1m /3.28ft
USB 3.2 Gen1 Type A to USB 3.2 Gen1 Type C Adapter M/F
USB Type A and C Dual Power Charger up to 60W
Product Series: Cables
Product Code: CAC-1526
EAN code: 8719214471903
UPC code: 841615102112
• Connect USB 3.2 Gen1 type C to micro USB enabled devices
• USB3.2 Gen1 data transfer rates up to 5Gbps when used with USB 3.2 Gen1 host and device
• Backwards compatible to support USB 3.0 and USB 2.0 specification.
• This cable is Bi-directional
• Supports both data and power
• Maximum Power output up to 10W
• All
• 1x CAC-1526 USB 3.2 Gen1 Type-C to Micro USB Cable M/M 1m /3.28ft
• USB Type C Male
• Micro USB Male
• Packaging size: 11 X 18 x 0.6cm/ 4.3 x 7.1 x 0.24"
• Bag Weigth: 5 gr/ 0.18 oz
• Cable Length: 1m / 3.28 ft
• Cable Weight: 27 gr/ 0.95 oz
• Total Weight: 32 gr/ 1.13 oz
