USB Gen2 Type-C to HDMI 4K120Hz 8K60Hz HDR10  with DSC1.2 Active Cable M/M  3m / 9.84ft
The Club 3D CAC-1587 USB Gen2 Type-C to HDMI™ 4K120Hz 8K60Hz HDR10+ with DSC1.2 Active Cable M/M 3m/9.84ft., is the perfect solution to connect to any HDMI™ 8K60Hz* or 4K120Hz ready display. In case you have a DisplayPort™ Alt Mode 1.4 ready PC with a USB Gen2 Type-C connection or any other device that lacks the new HDMI™ 8K60Hz or 4K120Hz specification, the Club3D CAC-1587 will be the simple way to upgrade your device and connect to your new TV*. With its DP1.4 Alt Mode DSC video compression technology, this Cable is able to convert DP1.4 Alt Mode video signals to HDMI™ , supporting video display resolutions up to 8K (7680 x 4320)@60Hz ** and creating life like colors and movements with HDR10+ giving users the ultimate visual experience. The Cable is powered thru the USB Gen2 Type-C connection.
Thunderbolt 4 Portable 5-in-1 Hub with Smart Power
USB Gen2 Type-C PD Charging Hub to 2x Type-C 10G ports and 2x USB Type-A 10G ports
USB 3.2 Gen1 Type-C 8-in-1 hub with 2x HDMI, 2x USB-A, RJ45, SD/Micro SD card slots and USB Type-C female port
USB Gen2 Type-C to HDMI™ 4K120Hz 8K60Hz HDR10+ with DSC1.2 Active Cable M/M 3m / 9.84ft
Product Series: Cable
Product Code: CAC-1587
EAN code: 8719214472351
UPC code: 841615102600
• Compliant with VESA DisplayPort™ v1.4 Specification
• Compliant with HDMI™ Specification
• Support HDCP 2.2
• Support Max. resolution/refresh rates up to [email protected], [email protected]
• Support Dynamic HDR10+
• Sound Support 5.1 - 7.1
• No External Power needed(Powered thru the USB Type-C connection)
Applications:
• For the host device like laptop, desktop, projector, gaming and display system like TV*, digital signage, VR/AR system.
• Perfect for Host Devices which are featured with the DP1.4 Alt Mode graphic card that supports DP video signal thru an USB Gen2 Type-C output for gaming, commercial applications**
Supported resolutions:
• Support Max. resolution/timing up to [email protected], [email protected]
•  Windows OS/ OSX and Chrome
• The Club 3D CAC-1587 USB Gen2 Type-C to HDMI™ 4K120Hz 8K60Hz HDR10+ with DSC1.2 Active Cable M/M 3m/9.84ft
• USB Gen2 Type-C Male
• 1x HDMI™ Male
• Box size: 14.5 x 14.5 x 4.5cm 5.71 x 5.71 x 1.77"
• Cable length approx.: 3m/9.84ft
• Connector dimensions:
- USB Type-C Male 2.2 x 1.22 x 0.64 cm / 0.87 x 0.48 x 0.25"
- HDMI™ Male 4.67 x 2.09 x 1.09 cm / 1.84 x 0.82 x 0.43"
• Cable Weight: 89 gr / 3.14 oz
• Box Weight: 45 gr / 1.59 oz
• Total Weight: 139 gr / 4.9 oz
Note:
