USB4 Gen3x2 Type-C Bi-Directional USB-IF Certified Cable 8K60Hz, Data 40Gbps, PD 240W(48V/5A) EPR M/M 1m / 3.28ft
The Club 3D CAC-1576 USB4 Gen3x2 Type-C Bi-Directional USB-IF Certified Cable 8K60Hz, Data 40Gbps, PD 240W(48V/5A) EPR M/M 1m / 3.28ft connects your Notebook, Tablet or Phone with USB4 Type-C output to your favorite existing Peripherals, Accessories and Chargers. It enables Video,Data and Power over a single cable and both ways. This cable supports USB4 Gen3x2 Type-C Bi-Directional Video 8K60Hz, Data 40Gbps, PD 240W(48V/5A) EPR M/M 1m / 3.28ft output for Downstream charging or powering your Notebook, Tablet or Smartphone and is USB-IF Certified.
Thunderbolt 4 Portable 5-in-1 Hub with Smart Power
USB Type-C Gen2 Angled Adapter  set of 2 up to 4K120Hz M/F
Product Series: Cables
Product Code: CAC-1576
EAN code: 8719214472320
UPC code: 841615102570
USB-IF: TID: 7472
• Video max. 8K60Hz
• USB4 Gen3x2 Data 40Gbps
• 240W EPR(Extended Power Range)Charging through a single cable
• Fully Bidirectional
• E-marker IC
• Data speed up to 40Gbps
• USB Power Delivery, 240 Watt(48V/5A) charging
• USB-IF Certified
• CAC-1576 USB4 Gen3x2 Type-C Bi-Directional USB-IF Certified Cable 8K60Hz, Data 40Gbps, PD 240W(48V/5A) EPR M/M 1m / 3.28ft
• USB Type-C Male
• USB Type-C Male
• Box size: 14.5 x 14.5 x 4.5cm / 5.71 x 5.71 x 1.77"
• Total Cable length approx.: 1m / 3.28ft
• USB Type-C Male Connector dimensions: 3.62 x 1.2 x 0.63 cm / 1.43 x 0.47 x 0.25"
• Cable Weight: 53 gr / 1.87 oz
• Box Weight: 45 gr / 1.59 oz
• Total Weight: 98 gr / 3.46 oz
