USB4 Gen3x2 Type-C Bi-Directional USB-IF Certified Cable 8K60Hz, Data 40Gbps, PD 240W(48V/5A) EPR M/M 1m / 3.28ft
The Club 3D CAC-1576 USB4 Gen3x2 Type-C Bi-Directional USB-IF Certified Cable 8K60Hz, Data 40Gbps, PD 240W(48V/5A) EPR M/M 1m / 3.28ft connects your Notebook, Tablet or Phone with USB4 Type-C output to your favorite existing Peripherals, Accessories and Chargers. It enables Video,Data and Power over a single cable and both ways. This cable supports USB4 Gen3x2 Type-C Bi-Directional Video 8K60Hz, Data 40Gbps, PD 240W(48V/5A) EPR M/M 1m / 3.28ft output for Downstream charging or powering your Notebook, Tablet or Smartphone and is USB-IF Certified.
Product Name: |
USB4 Gen3x2 Type-C Bi-Directional USB-IF Certified Cable 8K60Hz, Data 40Gbps, PD 240W(48V/5A) EPR M/M 1m / 3.28ft |
Product Series: Cables |
Product Code: CAC-1576 |
EAN code: 8719214472320 |
UPC code: 841615102570 |
• Video max. 8K60Hz |
• USB4 Gen3x2 Data 40Gbps |
• 240W EPR(Extended Power Range)Charging through a single cable |
• Fully Bidirectional |
• E-marker IC |
• Data speed up to 40Gbps |
• USB Power Delivery, 240 Watt(48V/5A) charging |
• Input Reversible USB Type-C connector Male |
• USB-IF Certified |
• Works with Windows, Apple OS X, Chrome OS |
• CAC-1576 USB4 Gen3x2 Type-C Bi-Directional USB-IF Certified Cable 8K60Hz, Data 40Gbps, PD 240W(48V/5A) EPR M/M 1m / 3.28ft |
Available Interfaces |
• USB Type-C Male |
• USB Type-C Male |
• Box size: 14.5 x 14.5 x 4.5cm / 5.71 x 5.71 x 1.77" |
• Total Cable length approx.: 1m / 3.28ft |
• USB Type-C Male Connector dimensions: 3.62 x 1.2 x 0.63 cm / 1.43 x 0.47 x 0.25" |
• Cable Weight: 53 gr / 1.87 oz |
• Box Weight: 45 gr / 1.59 oz |
• Total Weight: 98 gr / 3.46 oz |
- CAC-1576_SPECIFICATION-SHEET_EN.pdf
- CAC-1576_SPECIFICATION-SHEET_DE.pdf
- CAC-1576_SPECIFICATION-SHEET_ES.pdf
