Travel Charger 140 Watt GaN technology, Single port USB Type-C, Power Delivery(PD) 3.1 Support
The Club 3D CAC-1914 Travel Charger 140 Watt GaN technology, Single port USB Type-C, Power Delivery(PD) 3.1 Support is Compact in size & Superior in Performance: GaN technology chipset makes this charger 50% smaller than a traditional 140Watt Laptop charger, small enough to carry anywhere. Our CAC-1914 140Watt wall charger match a variety of PD devices from smart phones to laptops, one for all making charging simple. This wide compatibility charger will be your convenient companion during your business trip or vacation.
The Power Charger is light weight without compromising on Quality and safety. By adopting Power Delivery(PD)3.1 charging technology, this versatile Power Charger provides you with charging function through USB Type-C interface, you can charge any connected Mobile phone / Tablet / NoteBook. Furthermore all it needs is a free USB Type-C port on your Dock/NoteBook/Tablet/ Mobile phone to be charged via the bundled USB cable.
Charging: By adopting PD 3.1 Charging technology and charging function through USB Type-C interface the Club 3D Power Charger offers versatile and unique functionality. It will charge your devices up to 140 Watts. Built-in safeguards protect your devices against excessive current, overcharging and overheating(OCP-OTP-SCP-OVP).
USB2 Type-C Bi-Directional USB-IF Certified Cable, Data 480Mb, PD 240W(48V/5A) EPR M/M 2m/6.56ft
Product Series: Power Charger
Product Code: CAC-1914
EAN code: 8719214472689
UPC code: 841615102921
• Internal chip allows an input voltage of 100-240VAC 50/60Hz
• GaN technology
• 140 Watt of output power in total: Output USB Type-C: 5.0V/9.0V/12.0V/15.0V ≤ 3A, 20V≤5 A, 28V≤5 A Max. 140 Watt
• Power Delivery(PD) 3.1Support
• Accurate limited current output and over current protection(OCP)
• Overload protection and over voltage protection(OVP)
• Short circuit protection(SCP)
• Over temperature protection and remove the fault condition auto-recovery(OTP)
• Compliant with CE, FCC standards.
• Light weight and convenient to use.
• Specially designed for your USB Type-C supported devices.
• All
• CAC-1914 Travel Charger 140 Watt GaN technology, Single port USB Type-C, Power Delivery(PD) 3.1 Support
 - Mains connector (Specify on Order)
• 1x RED (Power ONLY) USB Type-C 240 Watt EPR cable(1 m / 3.28 ft) for connecting to Host
• 1x Mains connector
 (Specify on Order)
• USB Type-C Female
• Box size: 11 x 13 x 5.5cm / 4.33 x 5.12 x 2.16"
• Device size: 7.5 x 7.6 x 3.15cm / 2.95 x 2.99 x1.24"
• USB (Power) Cable length approx.: 1 m / 3.28 ft
• Device Weight: 333 gr / 11.75 oz
• USB Cable Weight: 35 gr / 1.2 oz
• Box Weight: 40 gr / 1.41 oz
• Total Weight(depending on PowerPlug) approx.: 413 gr / 14.53 oz
Warning Safe Usage: Only to be used at altitude 2000 meters/6562 feet and below
Some external devices, like the computer mouse, also need some power from the USB Port to operate. This power can be delivered through standard USB connection. The Default Power that USB 1.0 and 2.0 can deliver is 2.5Watt (5Volt, 0.5A), USB 3.0 and 3.1 can deliver 4.5Watt (5V, 0.9A), USB 3.2 can deliver 7.5W (5V/1.5A) and USB 4 can deliver 240Watt. For the external devices requiring more power, different technologies have been developed. It is important to distinguish following 2 technologies: "USB Power Delivery" and "USB Battery Charging".
