International Travel Charger 140W GaN technology, Four port USB Type-A(1x) and -C(3x), PPS + Power Delivery(PD) 3.1 Support
The Club 3D CAC-1917 International Travel Charger 140W GaN technology, Four port USB Type-A(1x) and -C(3x), PPS + Power Delivery(PD) 3.1 Support is a high-performance and fashionable design travel charger.
Versatility: Perfect solution for business travelers and power users, with interchangeable plugs to fit different countries' needs and multiple ports. This means you only need one charger for all your devices, and you don't have to worry about carrying multiple adapters.
Portability: Highly portable and easy to carry (466 gr / 16.43 oz) in a backpack or luggage, making it ideal for business travelers who need to stay connected on the go without being weighed down by bulky chargers.
Powerful charging: The 142 Watt charger charges multiple devices simultaneously at high speed, while improving the life of your batteries at the same time. Ensuring busy travelers can stay productive on the move without waiting around for hours. Built-in safeguards protect your devices against excessive current, overcharging and overheating(OCP-OTP-SCP-OVP).
Product Name: |
International Travel Charger 140W GaN technology, Four port USB Type-A(1x) |
and -C(3x), PPS + Power Delivery(PD) 3.1 Support |
Product Code: CAC-1917 |
EAN code: 8719214472733 |
UPC code: 841615102976 |
• Internal chip allows an input voltage of 100-240VAC 50/60Hz |
• GaN technology |
• 140Watt of output power in total(single port usage): |
Output USB Type-C1: PD3.1: 5~15V ≤ 3A(45Watt), 20V~28V ≤ 5A(140Watt MAX) |
PPS: 5V-21V/5A (100Watt MAX) |
Output USB Type-C2: PD3.1: 5V3A/9V3A/15V3A/20V3.25A(65Watt MAX) |
PPS: 3.3V-21V ≤ 3.25A (65Watt MAX) |
Output USB Type-C3: PD3.1: 5V3A/9V3A/15V3A/20V3.25A(65Watt MAX) |
Output of the USB Type-A port can convey 5V ≤ 2.4A(12W) |
• The maximum power output for single USB Type-C port is 140Watt |
• Power Delivery(PD) 3.1Support |
• Accurate limited current output and over current protection(OCP) |
• Overload protection and over voltage protection(OVP) |
• Short circuit protection(SCP) |
• Over temperature protection and remove the fault condition auto-recovery(OTP) |
• Compliant with CE, FCC standards. |
• Mains connector interchangeable |
• Portable and convenient to use. |
• Specially designed for your USB Type-C supported devices. |
• All |
• CAC-1917 International Travel Charger 140W GaN technology, Four port USB Type-A(1x) and -C(3x), PPS + Power Delivery(PD) 3.1 Support |
• 4 different mains connectors interchangeable |
• 1x USB Type-C Power Certified 240W(48V/5A) EPR cable(1 m / 3.28 ft) |
Available Interfaces |
• 1x Mains connector interchangeable |
• USB Type-A Female(1x) |
• USB Type-C Female(3x) |
• Box size: 11 x 13 x 5.5cm / 4.33 x 5.12 x 2.16" |
• Device size: 9.6 x 7.6 x 3.1 cm / 3.78 x 2.99 x 1.22" |
• Device Weight(Depending on mains connector): approx. 387 gr / 13.65 oz |
• USB Cable Weight: 34 gr / 1.2 oz |
• Box Weight: 38 gr / 1.34 oz |
• LDPE Bag Weight: 6 gr / 0.21 oz |
• Total Weight(depending on mains connector) approx.: 466 gr / 16.43 oz |
• Warning Safe Usage – Only to be used at altitude 2000 meters/6562 feet and below |
- CAC-1917_SPECIFICATION-SHEET_EN.pdf
- CAC-1917_SPECIFICATION-SHEET_DE.pdf
- CAC-1917_SPECIFICATION-SHEET_ES.pdf
