The Club 3D CAC-1088 is the perfect solution to connect to any HDMI™ 4K120Hz/8K60Hz ready displays*. If you have a DisplayPort™ 1.4 ready PC or any other device that lacks the new HDMI™ 4K120Hz/8K60Hz specification, the Club3D CAC-1088 will be the simple way to upgrade your device and connect to your new TV*.
 With its DP1.4 DSC video compression technology, this adapter is able to convert DP1.4 video signals to HDMI™, supporting video display resolutions up to 8K (7680 x 4320)@60Hz ** and creating life like colors and movements with HDR giving users the ultimate visual experience. The Adapter does NOT need an external power cable.
Ultra High Speed HDMI 4K120Hz, 8K60Hz  Certified Cable 48Gbps M/M  1 m/3.28 ft
Ultra High Speed HDMI 4K120Hz, 8K60Hz  Cable 48Gbps M/M  3 m/ 9.84ft
DisplayPort™1.4 to HDMI™ 4K120Hz/8K60Hz HDR Active adapter M/F
Product Series: Adapter
Product Code: CAC-1088
EAN code: 8719214472740
UPC code: 841615102983
Upstream DisplayPort connection to host:
• Compliant with VESA DisplayPort™ v1.4 Specification
• Support DSC1.1/1.2a or uncompressed video
• Support DSC 1.1/1.2a decoder
• Support 8/10/12 bit color depth
• Support pixel format RGB
Downstream HDMI connection to display
• Compliant with HDMI™ Specification max. 8K (7680x4320)@60Hz
• Support Dynamic metadata HDR10+
• Support HPD (DisplayPort Hot Plug Detect)
• Support both HDCP 1.4 and HDCP 2.3
• Support 8/10/12 bit color depth output
• Support 1 to 32 channels LPCM 192kHz audio output
• Supports HBR audio up to 1536kHz
Applications:
• For the host device like laptop, desktop, video converter adaptor, docking station, projector, gaming and display system like TV*, digital signage, VR/AR system.
• Perfect for Host Devices which are featured with the DP1.4 graphic card that supports DP video signal output for gaming, commercial applications**.
Supported resolutions:
• Support Max. resolution/timing up to 4k120Hz/8K60Hz
This product is SPECIFICALLY designed to work with the latest Graphics Processing Units (GPU’s) which supports DSC 1.2
This adapter will function with lower specifications GPU’s, be aware performance will be reduced due to the specifications of that GPU !!
Functionality is also dependent on the HDMI™ M/M cable used. In combination with this CAC-1088 adapter, we advise using HDMI™ Male/Male cable of 28AWG Quality or above, like the Club 3D CAC-1371 or CAC-1373 up to 3m/9.84ft max. !
• Windows 10 & 11
• 1x CAC-1088 Active Adapter
• 1x DP1.4 (Male)
• 1x HDMI™ (Female)
Note: Max. HDMI™ extension cable length is 3m/9.84ft !!
• Box size: 24 x 6 x 3.5 cm / 2.36 x 9.45 x 1.38"
• Device size: 4.9 x 2.25 x 1.15 cm/ 1.93 x 0.88 x 0.45"
• Output Cable length approx.: 10 cm / 3.94"
• Connector dimensions: DisplayPort™ Male 5.1 x 2 x 1.5 cm / 2.0 x 0.79 x 0.6 "
• Device Weight: 51 gr / 1.8 oz
• Box Weight: 28 gr / 0.99 oz
• LDPE Bag Weight: 5gr / 0.18 oz
• Total Weight: 84 gr / 2.97 oz
Note:
