Notebook / Laptop Car Charger 36 Watt
The Club 3D CAC-1921 product is a high-performance and fashionable design Car charger. With this charger, it is feasible for you to charge any devices (eg: digital cameras, PDAs, mobile phones, USB accessories) with your car when it is in necessity. It is equipped with three USB connectors (one USB Type-C connector and two USB Type-A connector) for power. This product allows three devices to be charged at the same time, and the product provides the maximum output of 36 watts. The USB Type-C port is specially designed for Type-C supported devices. Please make absolutely sure that you're using the cables with the correct Power rating from Club 3D. We advise to use minimal 60Watt rated cables just to make sure you're making optimal use of the benefits of this charger. It is helpful and convenient to use!
![]() | CAC-1921QUICK INSTALLATION GUIDE | ![]() | CAC-1921QUICK INSTALLATION GUIDE |
Product Name: |
Notebook / Laptop Car Charger 36 Watt |
Product Series: Power |
Product Code: CAC-1921 |
EAN code: 8719214472788 |
UPC code: 841615103041 |
• Internal chip allows either 12 or 24VDC of input voltage. |
• Two methods for charging: |
• USB Type-A port ONLY: QC3.0 12V/3A(36Watt Max.) |
• Double USB Type-A: 5V/3A + USB Type-C: 5V/3A, 9V/2A,(33 Watt Max.) |
• Accurate limited current output and over current protection(OCP). |
• Overload protection and over voltage protection(OVP). |
• Short circuit protection(SCP). |
• Over temperature protection(OTP) with auto-recovery. |
• Specifically designed for your USB Type-C supported devices. |
• Compliant with UL,CE, FCC, standards. |
Warning Safe Usage – Product Only to be used at altitude 2000 meters/6562 feet and below |
• Windows & Apple OS |
• 1x CAC-1921 Notebook / Laptop Car Charger 36 Watt |
• QIG, Quick Installation Guide (or download link) |
Available Interfaces |
• 1x Car Cigarette Lighter 12-24Volt DC |
• USB Type-A Female(2x) |
• USB Type-C Female(1x) |
• Device size: 6.68 x 3.63 cm / 2.63 x 1.43" |
• Device Weight: 29 gr./ 1.03 oz |
• Box size: 6 x 7 x 4 cm/ 2.36 x 2.76 x 1.58" |
• Box Weight: 12 gr./ 0.42 oz |
• Bio Degradable Bag size: 10 x 12 cm/ 3.93 x 4.72" |
• Bio Degradable Bag Weight: 4 gr./ 0.14 oz |
• Total Weight approx.: 54 gr./ 1.9 oz |
- CAC-1921_SPECIFICATION-SHEET_EN.pdf
- CAC-1921_SPECIFICATION-SHEET_DE.pdf
- CAC-1921_SPECIFICATION-SHEET_ES.pdf
- CAC-1921-QUICK INSTALL-GUIDE_EN.pdf
- CAC-1921-QUICK INSTALL-GUIDE_DE.pdf
- CAC-1921-QUICK INSTALL-GUIDE_ES.pdf
- CAC-1921BOX-3D-HR.zip
- CAC-1921-QUICK INSTALL-GUIDE_EN.pdf.zip
- CAC-1921-QUICK INSTALL-GUIDE_DE.pdf.zip
- CAC-1921-QUICK INSTALL-GUIDE_ES.pdf.zip
