Notebook / Laptop Power Car Charger 63 Watt
The Club 3D CAC-1922 is a high-performance and fashionable design max. 63Watt Car charger with QC3.0 and Power Delivery (PD) support. With this charger, it is feasible for you to charge any devices (eg: digital cameras, PDAs, notebook computer, mobile phones, USB accessories) with your car when it is in necessity. It is equipped with two USB connectors (one USB Type-C connector and one USB Type-A connector) for power. This product allows two devices to be charged at the same time, and the product provides the maximum output of 63 watts. The USB-C port is specially designed for Type-C supported devices. To distinguish between QC and PD charging, the LED light turns blue for Quick Charge(QC) or Red for Power Delivery(PD) mode.
Ensuring busy travelers can stay productive on the move without waiting around for hours. Built-in safeguards protect your devices against excessive current, overcharging and overheating(OCP-OTP-SCP-OVP).
Please use an USB cable suitable to handle at least 60Watt with PD support. We recommend our CAC-1511 or CAC-1515.
CAC-1922 QUICK INSTALLATION GUIDE
USB2 Type-C Bi-Directional USB-IF Certified Cable Data 480Mb, PD 240W(48V/5A) EPR M/M 1m / 3.23 ft
USB Type-C Gen 2 Active Cable 4K60Hz 10Gbps PD 100W M/M 1 m/ 3.28 ft
Product Series: Power
Product Code: CAC-1922
EAN code: 8719214472795
UPC code: 841615103058
• Internal chip allows either 12 or 24VDC of input voltage.
• Two ports for charging:
 • USB Type-A port ONLY: 3.3V~6.5V/3A, 6.5V~9V/2A, 9V~12V/1.5A, compliant with Qualcomm Quick Charge(QC)3.0
 • USB Type-C port ONLY: 5V/3A, 9V/3A, 12V/3A ,15V/3A,20V/3A
 • Both ports working USB-Type C + USB Tpe-A: 5V/3A, 9V/3A, 12V/3A ,15V/3A,20V/2.25A
• Accurate limited current output and over current protection(OCP).
• Overload protection and over voltage protection(OVP).
• Short circuit protection(SCP).
• Over temperature protection(OTP) with auto-recovery.
• Specifically designed for your USB Type-C supported devices.
• Compliant with UL,CE, FCC, standards.
Warning Safe Usage – Product Only to be used at altitude 2000 meters/6562 feet and below
• Windows & Apple OS
• 1x CAC-1922 Notebook / Laptop Power Car Charger 63 Watt
• QIG, Quick Installation Guide (or download link)
• 1x Car Cigarette Lighter 12-24Volt DC
• USB Type-A Female(1x)
• USB Type-C Female(1x)
• Device size: 6.35 x 3.7 cm / 2.5 x 1.46"
• Device Weight: 38 gr./ 1.34 oz
• Box size: 6 x 7 x 4 cm / 2.36 x 2.76 x 1.58"
• Box Weight: 12 gr./ 0.42 oz
• Bio Degradable Bag size: 10 x 12 cm / 3.94 x 4.72"
• Bio Degradable Bag Weight: 4 gr./ 0.14 oz
• Total Weight approx.: 54 gr./ 1.9 oz
Some external devices, like the computer mouse, also need some power from the USB Port to operate. This power can be delivered through standard USB connection. The Default Power that USB 1.0 and 2.0 can deliver is 2.5Watt (5Volt, 0.5A), USB 3.0 and 3.1 can deliver 4.5Watt (5V, 0.9A), USB 3.2 can deliver 7.5W (5V/1.5A) and USB 4 can deliver 240Watt. For the external devices requiring more power, different technologies have been developed. It is important to distinguish following 2 technologies: "USB Power Delivery" and "USB Battery Charging".
