USB Type-C Cable to DP 2.1 Bi-Directional VESA DP80 Certified Cable M/M 1m/3.28ft
The Club 3D CAC-1559 USB Type-C to DisplayPort™ 2.1 Bi-Directional DP80™ Coaxial Cable, 4K240Hz, 8K60Hz or 10K60Hz M/M 1 m/3.28ft enables the connection of your USB Type-C supported (Gaming) PC or Laptop to an (Ultra) High Resolution Monitor or other DisplayPort™ supported device. DisplayPort™ 2.1 UHBR10/13.5/20 up till 80 Gbps, also has support for Display Stream Compression 1.2 (DSC), Forward Error Correction, and extends the maximum number of inline audio channels to 32. It features locking DisplayPort™ connector providing a secure, dependable connection, with NEW contact fingers special designed for these high speeds. Simply press the built-in one-touch latch button to unlock the connector. The soft UltraFlex jacket protects the cable from bends and deformation damage.
Product Name: USB Type-C to DisplayPort DP80 Bidirectional Vesa Certified Cable 1m/ 3.28 ft |
Product Series: Cable |
Product Code: CAC-1559 |
EAN-Code: 8719214473099 |
UPC-Code: 841615103348 |
• Fully DisplayPort™ Version 2.1 Compliant, UHBR10/13.5/20 up till 80 Gbps |
• DP80™ Compliant |
• New DP2.1 spec connector |
• USB must support new standard DisplayPort 2.1 (DP80) Alternate Mode |
• Downwards compatible to older DisplayPort™ standards |
• Support resolutions up to 4K240Hz or 8K60Hz or 10K60Hz |
• Fully Bidirectional |
• VESA Certified |
Supported resolutions: |
• Up to 4K240Hz, 8K60Hz or 10K60Hz |
• All |
Available Interfaces: |
• USB Type-C Male |
• DisplayPort™ 2.1 Male |
• 1X CAC-1559 USB Type-C to DisplayPort DP80 Bidirectional Vesa Certified Cable 1m/ 3.28 ft |
• Box size: 14.5 x 14.5 x 4.5 cm / 5.74 x 5.71 x 1.77" |
• Cable length approx.: 1m / 3.28 ft |
• Connector dimensions: |
- USB Type-C- 4.2 x 1.2 x 0.6 cm / 1.65 x 0.47 x 0.24" |
- DP80™ 3.7 x 1.9 x 0.9 cm / 1.45 x 0.75 x 0.35 " |
• Device Weight: 59 gr. / 2.08 oz |
• Box Weight: 45 gr./ 1.59 oz |
• Bio Degradable Bag size: 12.2 cm / 4.8 " |
• Bio Degradable Bag Weight: 5 gr / 0.17 oz |
• Total Weight: 109 gr / 3.8 oz |
- CAC-1559_SPECIFICATION-SHEET_EN.pdf
- CAC-1559_SPECIFICATION-SHEET_DE.pdf
- CAC-1559_SPECIFICATION-SHEET_ES.pdf
